Inleiding
Use this guide to open the Huawei Watch 3 and remove the back cover.
Wat je nodig hebt
User your fingernail to pull the small metal pin on each wrist band towards the inside. This unlocks the wrist bands from the body of the watch.
Remove the wrist bands.
Use a Torx T3 screwdriver to remove the four 4 mm-long screws on the back of the Huawei Watch 3.
Locate the small notch at the top of the back cover.
Use a Jimmy to pry open the back cover by twisting it.
Insert the tip of an opening pick between the back cover and the case.
Slide the opening pick around the back cover to loosen the gasket from the back cover.
Use an opening pick or your fingers to carefully lift the back cover open.
Flip the back cover open away from the crown.
Use a Phillips screwdriver to remove the 2.9 mm-long screw from the battery bracket.
User a pair of tweezers to lift the top of the battery bracket free from its screw socket.
Unhook the opposite side of the bracket and remove it.
Use the tip of a spudger to pry up and disconnect the battery connector.
Use a Phillips screwdriver to remove the 2.9 mm-long screw from the sensor bracket.
User a pair of tweezers to move the top of the sensor bracket free from a small latch near the case by rotating in inwards.
Use the tip of a spudger to pry up and disconnect the sensor connector.
Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our https://www.ifixit.com/Answers/Device/Hu... for help.
Één andere persoon heeft deze handleiding voltooid.
