Ga door naar hoofdinhoud
Opening the Hood
  1. Opening the Hood, Opening the Hood: stap 1, afbeelding 1 van 2 Opening the Hood, Opening the Hood: stap 1, afbeelding 2 van 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
    Vraag FixBot
    Voeg opmerking toe
  2. Opening the Hood: stap 2, afbeelding 1 van 2 Opening the Hood: stap 2, afbeelding 2 van 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
    Vraag FixBot
    Voeg opmerking toe
  3. Opening the Hood: stap 3, afbeelding 1 van 2 Opening the Hood: stap 3, afbeelding 2 van 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Shaun MacDonald
2.654 Reputatie
8 handleidingen geschreven
Cal Poly, Team 24-27, Regan Fall 2012 Lid van Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Leden
24 handleidingen geschreven
1Gids Commentaar
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 49
Afgelopen 7 dagen: 293
Afgelopen 30 dagen: 1,285
Altijd: 84,473
