Ga door naar hoofdinhoud
Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement
Wat je nodig hebt
  1. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: stap 1, afbeelding 1 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: stap 1, afbeelding 2 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 2, afbeelding 1 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 2, afbeelding 2 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 2, afbeelding 3 van 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 3, afbeelding 1 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 3, afbeelding 2 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 3, afbeelding 3 van 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 4, afbeelding 1 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 4, afbeelding 2 van 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: stap 4, afbeelding 3 van 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Auxiliary Port: stap 5, afbeelding 1 van 1
    • With your solderwick and soldering iron, remove the solder at each point, and gently pull the 3.5mm port away from the motherboard with your tweezers.
    • For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 236
