Ga door naar hoofdinhoud
OnePlus Nord N20 5G Speaker Replacement
Wat je nodig hebt
  1. OnePlus Nord N20 5G Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Insert the SIM ejection tool or a spudger in the small hole next to the SIM tray.
    • Push it gently until the tray pops out.
    • Remove the SIM card tray by sliding it outwards.
  2. OnePlus Nord N20 5G Speaker Replacement: stap 2, afbeelding 1 van 2 OnePlus Nord N20 5G Speaker Replacement: stap 2, afbeelding 2 van 2
    • Heat the iOpener in a microwave for about 30 seconds. If the iOpener isn’t hot enough, reheat it for another 10-30 seconds.
    • Apply the heated iOpener on the backside of the phone for a minute to loosen the adhesive.
    • Use the iFixit opening tool and slide it along the edges of the phone to pry the back panel off.
  3. OnePlus Nord N20 5G Speaker Replacement, Speaker: stap 3, afbeelding 1 van 1
    • Remove the 18 3.9 mm screws using a Phillips #0 screwdriver.
  4. OnePlus Nord N20 5G Speaker Replacement: stap 4, afbeelding 1 van 1
    • Take the iFixit opening tool and run it along the edges of the frame.
    • Separate the back housing from the frame of the screen.
  5. OnePlus Nord N20 5G Speaker Replacement: stap 5, afbeelding 1 van 3 OnePlus Nord N20 5G Speaker Replacement: stap 5, afbeelding 2 van 3 OnePlus Nord N20 5G Speaker Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to gently lift the speaker, disconnecting it from the motherboard.
    • Remove the speaker from the device.
Conclusie
Mila
219 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 43
