Ga door naar hoofdinhoud
OnePlus 6T Front Camera Replacement
Wat je nodig hebt
  1. OnePlus 6T Front Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Vraag FixBot
    Voeg opmerking toe
  2. OnePlus 6T Front Camera Replacement: stap 2, afbeelding 1 van 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Vraag FixBot
    Voeg opmerking toe
  3. OnePlus 6T Front Camera Replacement: stap 3, afbeelding 1 van 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. OnePlus 6T Front Camera Replacement: stap 4, afbeelding 1 van 3 OnePlus 6T Front Camera Replacement: stap 4, afbeelding 2 van 3 OnePlus 6T Front Camera Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Vraag FixBot
    Voeg opmerking toe
  5. OnePlus 6T Front Camera Replacement, Front Camera: stap 5, afbeelding 1 van 2 OnePlus 6T Front Camera Replacement, Front Camera: stap 5, afbeelding 2 van 2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
    Vraag FixBot
    Voeg opmerking toe
  6. OnePlus 6T Front Camera Replacement: stap 6, afbeelding 1 van 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
    Vraag FixBot
    Voeg opmerking toe
  7. OnePlus 6T Front Camera Replacement: stap 7, afbeelding 1 van 1
    • Using a spudger, gently remove the midframe and place it to the side.
    Vraag FixBot
    Voeg opmerking toe
  8. OnePlus 6T Front Camera Replacement: stap 8, afbeelding 1 van 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Kristen Gismondi
107.806 Reputatie
270 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
28.236 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 53
Altijd: 1,785
