Ga door naar hoofdinhoud
OnePlus 6 Screen Replacement
Wat je nodig hebt
  1. OnePlus 6 Screen Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
    Vraag FixBot
    Voeg opmerking toe
  2. OnePlus 6 Screen Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Screen Replacement: stap 2, afbeelding 2 van 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  3. OnePlus 6 Screen Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Screen Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
    Vraag FixBot
    Voeg opmerking toe
  4. OnePlus 6 Screen Replacement, Battery: stap 4, afbeelding 1 van 2 OnePlus 6 Screen Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
    Vraag FixBot
    Voeg opmerking toe
  5. OnePlus 6 Screen Replacement, Speaker: stap 5, afbeelding 1 van 1
    • Use a Phillips #000 screwdriver to remove the eight screws.
    • Carefully lift the speaker up and out of the chassis.
    • If you're completing a screen replacement, skip to Step 9.
    Vraag FixBot
    Voeg opmerking toe
  6. OnePlus 6 Screen Replacement: stap 6, afbeelding 1 van 1
    • Properly orient the new speaker unit and use a Phillips #000 screwdriver to replace the eight screws removed from the previous step.
    Vraag FixBot
    Voeg opmerking toe
  7. OnePlus 6 Screen Replacement: stap 7, afbeelding 1 van 1
    • Place the battery back into the phone and connect it to the same port, making sure to firmly press the connection down into place.
    • Place the red cover back over the top of the port.
    Vraag FixBot
    Voeg opmerking toe
  8. OnePlus 6 Screen Replacement: stap 8, afbeelding 1 van 1
    • Strip the existing adhesive, and place new adhesive around the entire perimeter of the back cover.
    • Replace the back cover and hold it down for about a minute to to let the adhesive set.
    Vraag FixBot
    Voeg opmerking toe
  9. OnePlus 6 Screen Replacement, Screen: stap 9, afbeelding 1 van 1
    • Use tweezers to gently pull away the tab securing the audio jack to the speaker assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. OnePlus 6 Screen Replacement: stap 10, afbeelding 1 van 1
    • After removing the band, gently lift the audio jack out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  11. OnePlus 6 Screen Replacement: stap 11, afbeelding 1 van 2 OnePlus 6 Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the white and black leads by gently lifting them up with tweezers.
    • Lift the band connector on the left side of the assembly up with tweezers to disconnect it.
    • Lift the band connector at the top of the assembly up with tweezers to disconnect it.
    Vraag FixBot
    Voeg opmerking toe
  12. OnePlus 6 Screen Replacement: stap 12, afbeelding 1 van 1
    • Using tweezers, lift the circuit board from the assembly and remove it.
    Vraag FixBot
    Voeg opmerking toe
  13. OnePlus 6 Screen Replacement: stap 13, afbeelding 1 van 1
    • Use a heat gun set to its lowest temperature, gently heat the perimeter of the screen to loosen the adhesive.
    • Wedge an opening pick between the screen and the chassis, then slide it around the entire perimeter of the screen to break the adhesive.
    • Gently pry the screen away from the chassis.
    • Reheat the perimeter as needed.
    Vraag FixBot
    Voeg opmerking toe
  14. OnePlus 6 Screen Replacement: stap 14, afbeelding 1 van 2 OnePlus 6 Screen Replacement: stap 14, afbeelding 2 van 2
    • After gently prying the screen from the frame, carefully thread the tab through the bracket to remove the screen from the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
Works great, thank you very much. I changed the microphone with this instruction.
Kai Didschuneit - Antwoord Deel
Hi there!
The screen replacement works great with this howto.
But - sadly - my phone is now experiencing a huge battery drain. When fully charged it's dead after almost 6 ours. Also the fingerprint-reader is just working when the screen is on.
Does anyone has an idea howto solve this issues?
Thanks in advance!
flux - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 36
Afgelopen 30 dagen: 116
Altijd: 10,868
