Ga door naar hoofdinhoud
OnePlus 6 Lower Frame Replacement
Wat je nodig hebt
  1. OnePlus 6 Lower Frame Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Lower Frame Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Lower Frame Replacement: stap 2, afbeelding 2 van 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Lower Frame Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Lower Frame Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Lower Frame Replacement, Lower Frame: stap 4, afbeelding 1 van 2 OnePlus 6 Lower Frame Replacement, Lower Frame: stap 4, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the eight 3 mm screws from the lower frame.
    • Gently lift the lower panel up and out of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mickenzie Thompson
340 Reputatie
3 handleidingen geschreven
Clemson, Team 4-3, Hunter Fall 2021 Lid van Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 538
