Ga door naar hoofdinhoud
OnePlus 6 Front Facing Camera Replacement
Wat je nodig hebt
    1. OnePlus 6 Front Facing Camera Replacement, Front Facing Camera: stap 1, afbeelding 1 van 2 OnePlus 6 Front Facing Camera Replacement, Front Facing Camera: stap 1, afbeelding 2 van 2
      • Use a heat gun to gently heat the back edges of the phone to loosen the adhesive.
      • Use a plastic opening tool to pry the back cover up.
      • Start from one of the left corners and work your way around the phone using the plastic opening tool.
      • Carefully lift the back cover off.
      • Be careful not to damage or unseat the camera cable while removing the back cover.
      Vraag FixBot
      Voeg opmerking toe
    2. OnePlus 6 Front Facing Camera Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Front Facing Camera Replacement: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers to disconnect the red pull-away tab up from the motherboard.
      • Detach the orange camera ribbon cable, below the red tab, using the tweezers.
      • Grip the green tab and lift the battery up and out of the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. OnePlus 6 Front Facing Camera Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Front Facing Camera Replacement: stap 3, afbeelding 2 van 2
      • Use a Phillips #000 screwdriver to remove the ten screws from the motherboard harness.
      • Pull the motherboard harness up using the tweezers
      Vraag FixBot
      Voeg opmerking toe
    4. OnePlus 6 Front Facing Camera Replacement: stap 4, afbeelding 1 van 2 OnePlus 6 Front Facing Camera Replacement: stap 4, afbeelding 2 van 2
      • Use the pointed tip of a spudger to lift the front-facing camera's pin connection, gently prying on the plug vertically until it completely releases.
      • Lift the front-facing camera up and out using tweezers.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 39
Altijd: 1,173
