Ga door naar hoofdinhoud
OnePlus 6 Charging Port Replacement
Wat je nodig hebt
  1. OnePlus 6 Charging Port Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Charging Port Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Charging Port Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Charging Port Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Charging Port Replacement, Battery: stap 4, afbeelding 1 van 2 OnePlus 6 Charging Port Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Charging Port Replacement, Lower Frame: stap 5, afbeelding 1 van 2 OnePlus 6 Charging Port Replacement, Lower Frame: stap 5, afbeelding 2 van 2
    • Using the Phillips #00 screwdriver, remove the eight 3 mm screws from the lower frame.
    • Gently lift the lower panel up and out of the device.
  6. OnePlus 6 Charging Port Replacement, Charging Port: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the two 2.3 mm screws with the screwdriver located on the two ends of the charging port.
  7. OnePlus 6 Charging Port Replacement: stap 7, afbeelding 1 van 1
    Koop
    • Gently disconnect the four connectors surrounding the charging port using a pair of tweezers.
  8. OnePlus 6 Charging Port Replacement: stap 8, afbeelding 1 van 1
    • Pull the rubber strip up with your finger located just inside of the battery housing.
  9. OnePlus 6 Charging Port Replacement: stap 9, afbeelding 1 van 1
    • Using the tweezers, grab the charging port ribbon cable and pull it towards the top of the phone.
    • Gently remove the charging port and its cable from the device.
Conclusie
6 andere personen hebben deze handleiding voltooid.
John Steven Trammell
789 Reputatie
4 handleidingen geschreven
Clemson, Team 4-3, Hunter Fall 2021 Lid van Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Leden
14 handleidingen geschreven
Één opmerking
Helpful guide! However, there are some steps missing. Between step 7 and 9, the daughter board needs to be lifted up to make room to remove the charging port. It doesn't have to be fully removed, and it is held in place with some adhesive. Also, the charging port connects to the main-board, and that is held down by a plastic shield. Some screws will need to be removed. Once the plastic shield is removed, the charging port can be unplugged from the main-board and fully removed.
Menelik Seth - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 144
Altijd: 5,375
