Ga door naar hoofdinhoud
One Education Infinity Battery Replacement
Wat je nodig hebt
    1. One Education Infinity Battery Replacement, Back Case: stap 1, afbeelding 1 van 3 One Education Infinity Battery Replacement, Back Case: stap 1, afbeelding 2 van 3 One Education Infinity Battery Replacement, Back Case: stap 1, afbeelding 3 van 3
      • Always power off your device before beginning disassembly.
      • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. One Education Infinity Battery Replacement: stap 2, afbeelding 1 van 2 One Education Infinity Battery Replacement: stap 2, afbeelding 2 van 2
      • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
      Vraag FixBot
      Voeg opmerking toe
    3. One Education Infinity Battery Replacement: stap 3, afbeelding 1 van 3 One Education Infinity Battery Replacement: stap 3, afbeelding 2 van 3 One Education Infinity Battery Replacement: stap 3, afbeelding 3 van 3
      • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
      • Lift the back case off of the device.
      • Removing the back may create a loud snapping noise.
      Vraag FixBot
      Voeg opmerking toe
    1. One Education Infinity Battery Replacement, Battery: stap 4, afbeelding 1 van 3 One Education Infinity Battery Replacement, Battery: stap 4, afbeelding 2 van 3 One Education Infinity Battery Replacement, Battery: stap 4, afbeelding 3 van 3
      • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
      • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
      Vraag FixBot
      Voeg opmerking toe
    2. One Education Infinity Battery Replacement: stap 5, afbeelding 1 van 3 One Education Infinity Battery Replacement: stap 5, afbeelding 2 van 3 One Education Infinity Battery Replacement: stap 5, afbeelding 3 van 3
      • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
      • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
      • Lift the battery out from the internal case.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jacob Barnes
193 Reputatie
2 handleidingen geschreven
Cal Poly, Team S11-G4, Regan Fall 2019 Lid van Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 667
