Ga door naar hoofdinhoud
OnHub Congestion-sensing Antenna Replacement
Wat je nodig hebt
  1. OnHub Congestion-sensing Antenna Replacement, Speaker Grille: stap 1, afbeelding 1 van 2 OnHub Congestion-sensing Antenna Replacement, Speaker Grille: stap 1, afbeelding 2 van 2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Congestion-sensing Antenna Replacement: stap 2, afbeelding 1 van 1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Congestion-sensing Antenna Replacement: stap 3, afbeelding 1 van 2 OnHub Congestion-sensing Antenna Replacement: stap 3, afbeelding 2 van 2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
  4. OnHub Congestion-sensing Antenna Replacement, Congestion-sensing Antenna: stap 4, afbeelding 1 van 2 OnHub Congestion-sensing Antenna Replacement, Congestion-sensing Antenna: stap 4, afbeelding 2 van 2
    • Remove the wire connection to the antenna by soldering it off.
    • For help with soldering and de-soldering check out the iFixit Soldering Guide
Conclusie
3 andere personen hebben deze handleiding voltooid.
Joseph Ainsworth
544 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-3, Sullivan Spring 2016 Lid van USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 357
