Ga door naar hoofdinhoud
Olympus VR-350 LCD Screen Replacement
Wat je nodig hebt
    1. Olympus VR-350 LCD Screen Replacement, Front Plate: stap 1, afbeelding 1 van 2 Olympus VR-350 LCD Screen Replacement, Front Plate: stap 1, afbeelding 2 van 2
      • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Olympus VR-350 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Olympus VR-350 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Olympus VR-350 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Olympus VR-350 LCD Screen Replacement: stap 3, afbeelding 3 van 3
      • Use the plastic opening tools and your fingers to pry the front plate from the camera.
      • You might need to open the battery cover to remove the front plate.
      Vraag FixBot
      Voeg opmerking toe
    1. Olympus VR-350 LCD Screen Replacement, Back Plate: stap 4, afbeelding 1 van 2 Olympus VR-350 LCD Screen Replacement, Back Plate: stap 4, afbeelding 2 van 2
      • Use your fingers to pry open the back cover.
      • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
      • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    1. Olympus VR-350 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 1 van 2 Olympus VR-350 LCD Screen Replacement, LCD Screen: stap 5, afbeelding 2 van 2
      • Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
      Vraag FixBot
      Voeg opmerking toe
    2. Olympus VR-350 LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Pull the button pad up to fully reveal the visible ribbon cable.
      • You might need to bend the button pad out of the way.
      Vraag FixBot
      Voeg opmerking toe
    3. Olympus VR-350 LCD Screen Replacement: stap 7, afbeelding 1 van 1
      • Pull out the LCD screen and the ribbon cable.
      • The ribbon cable should be easy to pull out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Chloe
112 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-3, Leahy Winter 2015 Lid van USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 48
Altijd: 1,592
