Ga door naar hoofdinhoud
Olympus Stylus 410 Slider Replacement
Wat je nodig hebt
    1. Olympus Stylus 410 Slider Replacement, Slider: stap 1, afbeelding 1 van 1
      • Locate the 2 screws on the bottom of the slider.
      • Remove both screws with a #00 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Olympus Stylus 410 Slider Replacement: stap 2, afbeelding 1 van 1
      • Gently pull on the bottom of the slider until it comes off the lower track.
      • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
      Vraag FixBot
      Voeg opmerking toe
    3. Olympus Stylus 410 Slider Replacement: stap 3, afbeelding 1 van 1
      • Lift the slider up until it comes off the upper track.
      Vraag FixBot
      Voeg opmerking toe
    4. Olympus Stylus 410 Slider Replacement: stap 4, afbeelding 1 van 1
      • The slider should now be free from the body of the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jared Ruekberg
33 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-13, Maness Spring 2010 Lid van Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Leden
27 handleidingen geschreven
2Gids Commentaar
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - Antwoord Deel
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 69
Altijd: 4,671
