Ga door naar hoofdinhoud
Olympus D590 Retainer Clip Replacement
Wat je nodig hebt
    1. Olympus D590 Retainer Clip Replacement, Face Plate: stap 1, afbeelding 1 van 1
      • Remove five baseplate screws using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Olympus D590 Retainer Clip Replacement: stap 2, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
      Vraag FixBot
      Voeg opmerking toe
    3. Olympus D590 Retainer Clip Replacement: stap 3, afbeelding 1 van 1
      • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Olympus D590 Retainer Clip Replacement: stap 4, afbeelding 1 van 1
      • Using tweezers, lift the rubber plate to expose the ports.
      Vraag FixBot
      Voeg opmerking toe
    5. Olympus D590 Retainer Clip Replacement: stap 5, afbeelding 1 van 1
      • Remove two screws from the ports using a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    6. Olympus D590 Retainer Clip Replacement: stap 6, afbeelding 1 van 1
      • Use a spudger to pry the faceplate away from the rest of the camera.
      Vraag FixBot
      Voeg opmerking toe
    7. Olympus D590 Retainer Clip Replacement: stap 7, afbeelding 1 van 1
      • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
      • Damage to the connector line will prevent the on/off power switch's operational function.
      Vraag FixBot
      Voeg opmerking toe
    1. Olympus D590 Retainer Clip Replacement, Retainer Clip: stap 8, afbeelding 1 van 1
      • Orient the camera as shown, with the bottom facing up.
      • Open the retainer clip, by using your finger to push down and slide to the left.
      • The clip should pop open.
      Vraag FixBot
      Voeg opmerking toe
    2. Olympus D590 Retainer Clip Replacement: stap 9, afbeelding 1 van 1
      • Hold the retainer clip down (without re-latching it).
      • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Olympus D590 Retainer Clip Replacement: stap 10, afbeelding 1 van 1
      • Use tweezers to continue to remove the pin.
      Vraag FixBot
      Voeg opmerking toe
    4. Olympus D590 Retainer Clip Replacement: stap 11, afbeelding 1 van 1
      • When it feels loose, pull the pin all the way out with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    5. Olympus D590 Retainer Clip Replacement: stap 12, afbeelding 1 van 1
      • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Katie
31 Reputatie
3 handleidingen geschreven
Cal Poly, Team 28-23, Regan Spring 2010 Lid van Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 2,561
