Inleiding
The LED indicates the status of the camera and blinks to show activity. Despite the part's simple nature, the repair process is quite difficult. Replacement requires soldering and diving deep into the inner workings of the camera.
Wat je nodig hebt
Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
Remove the two 2mm screws from the left side panel.
Remove the single 3mm screw from the right side panel.
Remove the five 3mm screws from the bottom of the camera.
Remove the ribbon cable directly below the viewfinder.
Detach the white plastic clip from its socket with a pair of tweezers.
Disconnect the ribbon cable from the center of the board, near the central hole.
Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
Remove most of the camera components from the front of the case.
Remove the two 3 mm screws from the right side of the casing using a Phillips #00 screwdriver.
Pop the flash up to get access to the two body screws underneath.
Remove the two 3mm screws from under the flash using a Phillips #00 screwdriver.
