Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The lens may be cracked, dirty, or just need to be replaced. This guide is a difficult guide which involves removing many elements of the camera and soldering to reach the lens.
Wat je nodig hebt
Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
Remove the two 2mm screws from the left side panel.
Remove the single 3mm screw from the right side panel.
Remove the five 3mm screws from the bottom of the camera.
Remove the ribbon cable directly below the viewfinder.
Detach the white plastic clip from its socket with a pair of tweezers.
Disconnect the ribbon cable from the center of the board, near the central hole.
Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
Now we remove the bulk of the cameras components from the front of the case.
Unscrew the 2-3mm Screws from the right side of the casing
Pop the flash up, to get access to the two body screws underneath
Undo the 2-3mm screws
Één andere persoon heeft deze handleiding voltooid.
