Inleiding
If there are cracks or mars in the video display, the display screen may be broken.
Wat je nodig hebt
Remove front cover plate.
Unplug the USB and HDMI cables from the Oculus Rift DK2.
With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
4 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
It's possible to use the Samsung Galaxy Note 4 screen?
