Ga door naar hoofdinhoud
Oculus Rift DK1 Control Box Buttons Replacement
Wat je nodig hebt
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: stap 1, afbeelding 1 van 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: stap 1, afbeelding 2 van 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box Bottom Cover: stap 1, afbeelding 3 van 3
      • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
      • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
      Vraag FixBot
      Voeg opmerking toe
    2. Oculus Rift DK1 Control Box Buttons Replacement: stap 2, afbeelding 1 van 3 Oculus Rift DK1 Control Box Buttons Replacement: stap 2, afbeelding 2 van 3 Oculus Rift DK1 Control Box Buttons Replacement: stap 2, afbeelding 3 van 3
      • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
      • You can now remove the bottom lid of the control box. It should come apart easily.
      Vraag FixBot
      Voeg opmerking toe
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: stap 3, afbeelding 1 van 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: stap 3, afbeelding 2 van 3 Oculus Rift DK1 Control Box Buttons Replacement, Control Box  Motherboard: stap 3, afbeelding 3 van 3
      • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
      • When the DVI connector has cleared the casing, lift the motherboard.
      • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
      • When reassembling the device, ensure that all of the wires are clear of the buttons.
      Vraag FixBot
      Voeg opmerking toe
    2. Oculus Rift DK1 Control Box Buttons Replacement: stap 4, afbeelding 1 van 3 Oculus Rift DK1 Control Box Buttons Replacement: stap 4, afbeelding 2 van 3 Oculus Rift DK1 Control Box Buttons Replacement: stap 4, afbeelding 3 van 3
      • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
      • Do so for both of the wires attached to the motherboard.
      • Now fully separate the motherboard from the control box casing.
      Vraag FixBot
      Voeg opmerking toe
    1. Oculus Rift DK1 Control Box Buttons Replacement, Control Box Buttons: stap 5, afbeelding 1 van 1
      • You now have the motherboard separated from the control box.
      • Identify the buttons that are not working.
      Vraag FixBot
      Voeg opmerking toe
    2. Oculus Rift DK1 Control Box Buttons Replacement, Desoldering Button: stap 6, afbeelding 1 van 1
      • For each button that needs to be replaced, use a soldering iron and soldering braid to desolder the four metal points.
      • Be careful! Soldering iron is hot.
      Vraag FixBot
      Voeg opmerking toe
    3. Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: stap 7, afbeelding 1 van 2 Oculus Rift DK1 Control Box Buttons Replacement, Removing Button: stap 7, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Now that each button with issues is desoldered, use tweezers to grab each button and detach from the motherboard.
      • If the button does not come off easily, go back to the previous step and ensure each of the four metal points are properly desoldered.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ross De Vito
246 Reputatie
2 handleidingen geschreven
Cal Poly, Team 70-5, Forte Winter 2015 Lid van Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Leden
54 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 30
Altijd: 993
