Inleiding
The motherboard is the life of your smartphone. When your smart phone has lost its smarts, this is the guide to replace the coveted motherboard.
Wat je nodig hebt
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use tweezers or fingers to remove the three connector tabs.
8 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
how much is the mother board for oppo f1
Hi,I used a wrong car charger on my oppo n1 in the wrong port and since then my phone went off and never turns on.
Can I I sent the unit to you for repair?
I used a round pin car charger at the earpiece port of my oppo n1…and the phone went off…tiok it for repair but still not working…can u be off assistance
