Ga door naar hoofdinhoud
OLPC XO-4 Touch Power Button Replacement
Wat je nodig hebt
    1. OLPC XO-4 Touch Power Button Replacement, Battery: stap 1, afbeelding 1 van 1
      • Turn the laptop upside-down, with the handle facing away from you.
      Vraag FixBot
      Voeg opmerking toe
    2. OLPC XO-4 Touch Power Button Replacement: stap 2, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 2, afbeelding 2 van 2
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Vraag FixBot
      Voeg opmerking toe
    3. OLPC XO-4 Touch Power Button Replacement: stap 3, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 3, afbeelding 2 van 2
      • Lift up on the middle of the battery to remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. OLPC XO-4 Touch Power Button Replacement, Screen Frame: stap 4, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement, Screen Frame: stap 4, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement, Screen Frame: stap 4, afbeelding 3 van 3
      • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
      • Rotate the screen 180° and remove the other two screws.
      • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
      Vraag FixBot
      Voeg opmerking toe
    2. OLPC XO-4 Touch Power Button Replacement: stap 5, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement: stap 5, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement: stap 5, afbeelding 3 van 3
      • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
      • Repeat the step above for the panel on the other side.
      Vraag FixBot
      Voeg opmerking toe
    3. OLPC XO-4 Touch Power Button Replacement: stap 6, afbeelding 1 van 1
      • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
      • Gently lift up the lower part of the frame and pull it down to free the screen frame.
      Vraag FixBot
      Voeg opmerking toe
    4. OLPC XO-4 Touch Power Button Replacement: stap 7, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 7, afbeelding 2 van 2
      • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
      Vraag FixBot
      Voeg opmerking toe
    1. OLPC XO-4 Touch Power Button Replacement, Screen: stap 8, afbeelding 1 van 1
      • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. OLPC XO-4 Touch Power Button Replacement: stap 9, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 9, afbeelding 2 van 2
      • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
      • Carefully lift the screen out.
      Vraag FixBot
      Voeg opmerking toe
    3. OLPC XO-4 Touch Power Button Replacement: stap 10, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement: stap 10, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement: stap 10, afbeelding 3 van 3
      • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
      • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
      Vraag FixBot
      Voeg opmerking toe
    4. OLPC XO-4 Touch Power Button Replacement: stap 11, afbeelding 1 van 1
      • Remove the screen from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. OLPC XO-4 Touch Power Button Replacement, Back Cover: stap 12, afbeelding 1 van 1
      • Remove the four 6mm screws using a Phillips #1 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. OLPC XO-4 Touch Power Button Replacement: stap 13, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 13, afbeelding 2 van 2
      • Rotate the top half of the laptop so that the back cover is facing you.
      • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
      • Remove the back cover by gently lifting it off of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. OLPC XO-4 Touch Power Button Replacement, Wireless Card: stap 14, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement, Wireless Card: stap 14, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement, Wireless Card: stap 14, afbeelding 3 van 3
      • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
      • Gently pull out the two antenna connectors by pulling them away from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. OLPC XO-4 Touch Power Button Replacement: stap 15, afbeelding 1 van 1
      • Remove the black 4mm Phillips #1 screw holding the wireless card in.
      Vraag FixBot
      Voeg opmerking toe
    3. OLPC XO-4 Touch Power Button Replacement: stap 16, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 16, afbeelding 2 van 2
      • Remove the wireless card from the laptop by gently sliding it out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    1. OLPC XO-4 Touch Power Button Replacement, Motherboard: stap 17, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement, Motherboard: stap 17, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement, Motherboard: stap 17, afbeelding 3 van 3
      • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
      • Remove the metal cover from the laptop.
      Vraag FixBot
      Voeg opmerking toe
    2. OLPC XO-4 Touch Power Button Replacement: stap 18, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement: stap 18, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement: stap 18, afbeelding 3 van 3
      • Pull the connectors out by holding the plastic tabs and not the wires.
      • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
      • Unplug the two speaker wires from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. OLPC XO-4 Touch Power Button Replacement: stap 19, afbeelding 1 van 3 OLPC XO-4 Touch Power Button Replacement: stap 19, afbeelding 2 van 3 OLPC XO-4 Touch Power Button Replacement: stap 19, afbeelding 3 van 3
      • Turn the device over to where the screen used to be.
      • Pull out ribbon cable by holding the purple plastic tab.
      • Pull out connector with the black and white wire by holding plastic tab.
      Vraag FixBot
      Voeg opmerking toe
    4. OLPC XO-4 Touch Power Button Replacement: stap 20, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement: stap 20, afbeelding 2 van 2
      • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
      • Pull the motherboard out of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    1. OLPC XO-4 Touch Power Button Replacement, Power Button: stap 21, afbeelding 1 van 2 OLPC XO-4 Touch Power Button Replacement, Power Button: stap 21, afbeelding 2 van 2
      • Remove the power button by pinching in the four tabs until the power button can be pushed out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Matthew Smith
47 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-29, Amido Winter 2013 Lid van Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Leden
40 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 626
