Ga door naar hoofdinhoud
Nvidia Shield Tablet Motherboard Replacement
Wat je nodig hebt
    1. Nvidia Shield Tablet Motherboard Replacement, Rear Case: stap 1, afbeelding 1 van 2 Nvidia Shield Tablet Motherboard Replacement, Rear Case: stap 1, afbeelding 2 van 2
      • First, remove the stylus from your tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. Nvidia Shield Tablet Motherboard Replacement: stap 2, afbeelding 1 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 2, afbeelding 2 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      Vraag FixBot
      Voeg opmerking toe
    3. Nvidia Shield Tablet Motherboard Replacement: stap 3, afbeelding 1 van 2 Nvidia Shield Tablet Motherboard Replacement: stap 3, afbeelding 2 van 2
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      Vraag FixBot
      Voeg opmerking toe
    1. Nvidia Shield Tablet Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 1
      $7.95
      • Carefully use the precision tweezers to unplug the ribbon cable.
      • Be sure to have your anti-static wrist strap on for this procedure.
      Vraag FixBot
      Voeg opmerking toe
    2. Nvidia Shield Tablet Motherboard Replacement: stap 5, afbeelding 1 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 5, afbeelding 2 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 5, afbeelding 3 van 3
      • Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Nvidia Shield Tablet Motherboard Replacement: stap 6, afbeelding 1 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 6, afbeelding 2 van 3 Nvidia Shield Tablet Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
      • Use the flat end of the spudger tool to carefully pry up the motherboard.
      • In the first Shield, the stylus ribbon cable is located under the right side of board. While there are 2 additional cables for the cameras underneath the left end of the board. Be sure to loosen the cameras before lifting the board.
      Vraag FixBot
      Voeg opmerking toe
    4. Nvidia Shield Tablet Motherboard Replacement: stap 7, afbeelding 1 van 2 Nvidia Shield Tablet Motherboard Replacement: stap 7, afbeelding 2 van 2
      • Desolder the positive and negative battery cables from the motherboard.
      • Make sure to note which wire goes where, you don't want to re-solder the wires backwards!
      • The motherboard should now come free.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Molly Bauer
1.478 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-2, Blackwell Fall 2015 Lid van USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Leden
35 handleidingen geschreven
9Gids Commentaar
Where do you obtain a new motherboard?
imprintcave - Antwoord Deel
The real question is more about how to find a new shield tablet motherboard ??
willixlive - Antwoord Deel
where can i buy the motherboard
Gurjot Dhaliwal - Antwoord Deel
waar kan ik een nieuw shield moederbord kopen?
tom1vangestel - Antwoord Deel
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
Laurent Zanoni - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 52
Altijd: 10,366
