Inleiding
Follow these steps to replace the motherboard. The prerequisites are required to unsolder the items attached to it. You can simply unclip other items yourself, though.
Wat je nodig hebt
Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
Slide the spudger down each side until you hear numerous clicks.
Remove the back panel from the tablet.
Carefully remove any pieces of electrical tape that may be adhered to the battery.
Desolder the battery carefully from the motherboard.
For help with soldering, visit iFixit's How to Solder and Desolder Connections guide.
Disconnect each ribbon cable from their respective clips on the motherboard.
