Ga door naar hoofdinhoud
NuVision Duo 11 Battery Replacement
Wat je nodig hebt
  1. NuVision Duo 11 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
    • Slide the spudger down each side until you hear numerous clicks.
    • Remove the back panel from the tablet.
  2. NuVision Duo 11 Battery Replacement, Battery: stap 2, afbeelding 1 van 2 NuVision Duo 11 Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    • Carefully remove any pieces of electrical tape that may be adhered to the battery.
    • The tape may be adhered to wires; be sure to pull up the tape slowly.
  3. NuVision Duo 11 Battery Replacement: stap 3, afbeelding 1 van 1
  4. NuVision Duo 11 Battery Replacement: stap 4, afbeelding 1 van 1
    • Gently peel the battery from the front case.
    • You will be met with some resistance, so it is critical that you are very careful.
    • DO NOT puncture or bend the battery. It may explode or leak toxic chemicals.
Conclusie
Gavin Amaral
377 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-1, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 221
