Ga door naar hoofdinhoud
Nostalgia Electrics PCM805 Power Switch Replacement
Wat je nodig hebt
    1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: stap 1, afbeelding 1 van 2 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: stap 1, afbeelding 2 van 2
      • Unplug the device before following this guide.
      • First, place the device on its side, making sure the switch is not facing down.
      • Remove the eight 12mm Phillips #02 screws from the base.
      Vraag FixBot
      Voeg opmerking toe
    2. Nostalgia Electrics PCM805 Power Switch Replacement: stap 2, afbeelding 1 van 1
      • Gently separate the panel from the device.
      • Be sure not to tug at the wires that are still connected.
      Vraag FixBot
      Voeg opmerking toe
    1. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: stap 3, afbeelding 1 van 1
      • Locate the switch/wire assembly inside the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Nostalgia Electrics PCM805 Power Switch Replacement: stap 4, afbeelding 1 van 1
      • Pull back the insulation sleeves to expose the connector heads.
      Vraag FixBot
      Voeg opmerking toe
    3. Nostalgia Electrics PCM805 Power Switch Replacement: stap 5, afbeelding 1 van 2 Nostalgia Electrics PCM805 Power Switch Replacement: stap 5, afbeelding 2 van 2
      • Note the color of each wire and the order you remove them.
      • Using a pair of pliers, firmly grip the base of the wire.
      • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
      • Pull the wire straight out of the switch.
      • Repeat this step for each wire.
      Vraag FixBot
      Voeg opmerking toe
    4. Nostalgia Electrics PCM805 Power Switch Replacement: stap 6, afbeelding 1 van 2 Nostalgia Electrics PCM805 Power Switch Replacement: stap 6, afbeelding 2 van 2
      • Using pliers, pinch tabs at the top and bottom of switch.
      • While pinching the tabs, push the switch until the tabs are on the outside of the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Nostalgia Electrics PCM805 Power Switch Replacement: stap 7, afbeelding 1 van 2 Nostalgia Electrics PCM805 Power Switch Replacement: stap 7, afbeelding 2 van 2
      • Remove the switch from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Carlton
672 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-5, Hickman Winter 2015 Lid van USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Leden
16 handleidingen geschreven
1Gids Commentaar
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 2,317
