Ga door naar hoofdinhoud
Nook Simple Touch with GlowLight Motherboard Replacement
Wat je nodig hebt
  1. Nook Simple Touch with GlowLight Motherboard Replacement, Power Button: stap 1, afbeelding 1 van 1
    • Place the Nook with the screen facing down.
  2. Nook Simple Touch with GlowLight Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Wedge the opening tool between the power button and the upper edge of the device.
    • Push the opening tool down to pry the power button up.
  3. Nook Simple Touch with GlowLight Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using your fingers, gently remove the power button.
  4. Nook Simple Touch with GlowLight Motherboard Replacement, Back Cover: stap 4, afbeelding 1 van 1
    • Remove the single screw using a T4 Torx screwdriver.
  5. Nook Simple Touch with GlowLight Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Slide the back cover down towards you in the direction of the charging port.
  6. Nook Simple Touch with GlowLight Motherboard Replacement, Battery: stap 6, afbeelding 1 van 2 Nook Simple Touch with GlowLight Motherboard Replacement, Battery: stap 6, afbeelding 2 van 2
    • Detach the white cable connector from the motherboard.
    • Remove the battery from the device.
  7. Nook Simple Touch with GlowLight Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Remove eleven screws from the motherboard using the T4 screwdriver.
  8. Nook Simple Touch with GlowLight Motherboard Replacement: stap 8, afbeelding 1 van 3 Nook Simple Touch with GlowLight Motherboard Replacement: stap 8, afbeelding 2 van 3 Nook Simple Touch with GlowLight Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the orange ribbon cable from the motherboard.
    • Using your fingers, gently lift the motherboard from the display.
Conclusie
Sydney Segear
401 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 104
