Ga door naar hoofdinhoud
Nook HD+ Charging Port Replacement
Wat je nodig hebt
  1. Nook HD+ Charging Port Replacement, Motherboard: stap 1, afbeelding 1 van 3 Nook HD+ Charging Port Replacement, Motherboard: stap 1, afbeelding 2 van 3 Nook HD+ Charging Port Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Charging Port Replacement: stap 2, afbeelding 1 van 3 Nook HD+ Charging Port Replacement: stap 2, afbeelding 2 van 3 Nook HD+ Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Charging Port Replacement: stap 3, afbeelding 1 van 2 Nook HD+ Charging Port Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Charging Port Replacement: stap 6, afbeelding 1 van 2 Nook HD+ Charging Port Replacement: stap 6, afbeelding 2 van 2
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Charging Port Replacement: stap 7, afbeelding 1 van 2 Nook HD+ Charging Port Replacement: stap 7, afbeelding 2 van 2
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
  8. Nook HD+ Charging Port Replacement, Charging Port: stap 8, afbeelding 1 van 2 Nook HD+ Charging Port Replacement, Charging Port: stap 8, afbeelding 2 van 2
    • Once removing the motherboard, flip it over and locate the charging port. Use a soldering iron to disconnect the charging port from the motherboard. If confused here's a reference.
    • Since the charging port is attached to the motherboard, it is simpler to replace both.
    • Soldering iron will be very hot and can both burn your hand and possibly damage the device.
    • Solder the new charging port to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bayleigh Fouts
97 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Harley Spring 2022 Lid van IUPUI, Team 3-3, Harley Spring 2022
IUPUI-HARLEY-S22S3G3
3 Leden
3 handleidingen geschreven
Één opmerking
Where can I obtain the replacement part?? the new charging port???
Jim Rhem - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 664
