Inleiding
This guide will provide in depth steps in the replacement of a damaged or faulty speaker. When removing the speaker from your device some force will be necessary in their separation.
Wat je nodig hebt
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
