Inleiding
Be cautious when removing the back panel of the device. Buttons tend to become loose and fall out of place. Some force is necessary in removing the back and front panels.
Wat je nodig hebt
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Remove the tape which holds the wiring to the battery using a plastic opening tool.
5 andere personen hebben deze handleiding voltooid.
