Ga door naar hoofdinhoud
Nokia XL Dual SIM Disassembly
Alleen vereisten
Deze gids is alleen bedoeld voor beginners! Deze gids maakt deel uit van een andere procedure en is niet bedoeld om alleen te worden gebruikt.
Wat je nodig hebt
  1. Nokia XL Dual SIM Disassembly, Back Cover Removal: stap 1, afbeelding 1 van 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia XL Dual SIM Disassembly, Battery Removal: stap 2, afbeelding 1 van 2 Nokia XL Dual SIM Disassembly, Battery Removal: stap 2, afbeelding 2 van 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia XL Dual SIM Disassembly, Screen Separation part 1: stap 3, afbeelding 1 van 2 Nokia XL Dual SIM Disassembly, Screen Separation part 1: stap 3, afbeelding 2 van 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia XL Dual SIM Disassembly, Screen Separation part 2: stap 4, afbeelding 1 van 3 Nokia XL Dual SIM Disassembly, Screen Separation part 2: stap 4, afbeelding 2 van 3 Nokia XL Dual SIM Disassembly, Screen Separation part 2: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia XL Dual SIM Disassembly, System components: stap 5, afbeelding 1 van 1
    • Once the device is open, take note of all the components.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shadeed Bilal
231 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-4, Brown Fall 2014 Lid van USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 465
