Ga door naar hoofdinhoud
Nokia X Display Assembly Replacement
Wat je nodig hebt
  1. Nokia X Display Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia X Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia X Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia X Display Assembly Replacement, Display Assembly: stap 4, afbeelding 1 van 2 Nokia X Display Assembly Replacement, Display Assembly: stap 4, afbeelding 2 van 2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia X Display Assembly Replacement: stap 5, afbeelding 1 van 2 Nokia X Display Assembly Replacement: stap 5, afbeelding 2 van 2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia X Display Assembly Replacement: stap 6, afbeelding 1 van 1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
29 andere personen hebben deze handleiding voltooid.
Avery Dorsey
1.894 Reputatie
4 handleidingen geschreven
USF Tampa, Team 6-1, Brown Winter 2015 Lid van USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 23
Altijd: 6,362
