Ga door naar hoofdinhoud
Nokia N900 Camera Replacement
Wat je nodig hebt
  1. Nokia N900 Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Turn the phone around to the back. Sometimes the phone's back camera slider will not work. If this situation comes about replace your back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia N900 Camera Replacement: stap 2, afbeelding 1 van 1
    • In the case that you do need a new back cover remove it by locating the slit on the side of the phone allowing you to take off the cover, but if you need to further get to your camera you will need to remove the back cover as well.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia N900 Camera Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia N900 Camera Replacement: stap 4, afbeelding 1 van 1
    • Now that we have taken everything off the back of the phone we will need to take a screw driver and take the six screw located on the back out of the phone. This will allow you to take apart the phone in two halves.
    • Camera
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia N900 Camera Replacement: stap 5, afbeelding 1 van 1
    • You can use the blue plastic opening tool to remove the motherboard from the back of the phone.
    • The camera is located on the back of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia N900 Camera Replacement: stap 6, afbeelding 1 van 1
    • Your phone should now be able to separate into two pieces. One side being the back of the phone where the camera is located and the other being the side with the touch screen.
    • Back side of the phone where the camera is located
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia N900 Camera Replacement: stap 7, afbeelding 1 van 1
    • Here are the two main pieces of the camera.
    Vraag FixBot
    Voeg opmerking toe
  8. Nokia N900 Camera Replacement: stap 8, afbeelding 1 van 1
    • The camera can be popped out easily using a blunt knife or credit card. A new camera unit can be put into the same place. In case a Nokia N900 camera unit cannot be found, it is possible to use a Nokia N79 camera without causing damage.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Juan Haro
284 Reputatie
2 handleidingen geschreven
1Gids Commentaar
Where to find a camera part ?
Thanks
François Soltic - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 22
Altijd: 1,558
