Ga door naar hoofdinhoud
Nokia E90 Inside Screen Replacement
Wat je nodig hebt
  1. Nokia E90 Inside Screen Replacement, Front Cover: stap 1, afbeelding 1 van 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia E90 Inside Screen Replacement: stap 2, afbeelding 1 van 2 Nokia E90 Inside Screen Replacement: stap 2, afbeelding 2 van 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia E90 Inside Screen Replacement, Front Screen and Front Keypad: stap 3, afbeelding 1 van 1
    • With the front cover off, the screen and keypad should be loose.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia E90 Inside Screen Replacement: stap 4, afbeelding 1 van 2 Nokia E90 Inside Screen Replacement: stap 4, afbeelding 2 van 2
    • Using a plastic opening tool pry up the cable connecting the LCD screen to the rest of the phone.
    • With the cable disconnected, the screen should be free for removal or replacement.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia E90 Inside Screen Replacement, Inside Screen: stap 5, afbeelding 1 van 1
    • After removing the front screen and front keypad, your device should look like this.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia E90 Inside Screen Replacement: stap 6, afbeelding 1 van 3 Nokia E90 Inside Screen Replacement: stap 6, afbeelding 2 van 3 Nokia E90 Inside Screen Replacement: stap 6, afbeelding 3 van 3
    • Using the T5 Screwdriver, remove the two screws shown.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia E90 Inside Screen Replacement: stap 7, afbeelding 1 van 1
    • Make sure to remove the connection shown by gently easing the plastic opening tool underneath the connection and lightly prying the connection apart.
    Vraag FixBot
    Voeg opmerking toe
  8. Nokia E90 Inside Screen Replacement: stap 8, afbeelding 1 van 2 Nokia E90 Inside Screen Replacement: stap 8, afbeelding 2 van 2
    • Gently, lift the board up to reveal the front screen.
    Vraag FixBot
    Voeg opmerking toe
  9. Nokia E90 Inside Screen Replacement: stap 9, afbeelding 1 van 3 Nokia E90 Inside Screen Replacement: stap 9, afbeelding 2 van 3 Nokia E90 Inside Screen Replacement: stap 9, afbeelding 3 van 3
    • Using the plastic opening tool, lift and remove the inside screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
In order to install a new screen, simply follow the steps in reverse order with the new screen.
5 andere personen hebben deze handleiding voltooid.
Cameron Weinberg
591 Reputatie
6 handleidingen geschreven
Cal Poly, Team 18-21, Garner Spring 2011 Lid van Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 35
Altijd: 5,904
