Ga door naar hoofdinhoud
Nokia 8260 Microphone Replacement
Wat je nodig hebt
  1. Nokia 8260 Microphone Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the cell phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 8260 Microphone Replacement: stap 2, afbeelding 1 van 1
    • Press down on the round button on the back cover of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 8260 Microphone Replacement: stap 3, afbeelding 1 van 1
    • Slide the back cover down while still pressing the button.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 8260 Microphone Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia 8260 Microphone Replacement: stap 5, afbeelding 1 van 1
    • Press the end of the battery towards the top of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia 8260 Microphone Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia 8260 Microphone Replacement, Antenna: stap 7, afbeelding 1 van 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
    Vraag FixBot
    Voeg opmerking toe
  8. Nokia 8260 Microphone Replacement: stap 8, afbeelding 1 van 1
    • Pry open the antenna door by pulling down the top of the spudger
    Vraag FixBot
    Voeg opmerking toe
  9. Nokia 8260 Microphone Replacement: stap 9, afbeelding 1 van 1
    • Remove the antenna door.
    Vraag FixBot
    Voeg opmerking toe
  10. Nokia 8260 Microphone Replacement: stap 10, afbeelding 1 van 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
    Vraag FixBot
    Voeg opmerking toe
  11. Nokia 8260 Microphone Replacement, Circuit Board: stap 11, afbeelding 1 van 1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
    Vraag FixBot
    Voeg opmerking toe
  12. Nokia 8260 Microphone Replacement: stap 12, afbeelding 1 van 1
    • Remove the back covering.
    Vraag FixBot
    Voeg opmerking toe
  13. Nokia 8260 Microphone Replacement: stap 13, afbeelding 1 van 1
    • Remove the two screws at the top.
    Vraag FixBot
    Voeg opmerking toe
  14. Nokia 8260 Microphone Replacement: stap 14, afbeelding 1 van 1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  15. Nokia 8260 Microphone Replacement, Keypad: stap 15, afbeelding 1 van 1
    • Remove the plastic border lying on the keypad.
    Vraag FixBot
    Voeg opmerking toe
  16. Nokia 8260 Microphone Replacement: stap 16, afbeelding 1 van 1
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
    Vraag FixBot
    Voeg opmerking toe
  17. Nokia 8260 Microphone Replacement, Microphone: stap 17, afbeelding 1 van 1
    • Remove the microphone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Aaron Jen
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 27-94, Amido Spring 2010 Lid van Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,594
