Ga door naar hoofdinhoud
Nokia 8260 LCD Replacement
Wat je nodig hebt
  1. Nokia 8260 LCD Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the cell phone.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 8260 LCD Replacement: stap 2, afbeelding 1 van 1
    • Press down on the round button on the back cover of the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 8260 LCD Replacement: stap 3, afbeelding 1 van 1
    • Slide the back cover down while still pressing the button.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 8260 LCD Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia 8260 LCD Replacement: stap 5, afbeelding 1 van 1
    • Press the end of the battery towards the top of the phone.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia 8260 LCD Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia 8260 LCD Replacement, Antenna: stap 7, afbeelding 1 van 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
    Vraag FixBot
    Voeg opmerking toe
  8. Nokia 8260 LCD Replacement: stap 8, afbeelding 1 van 1
    • Pry open the antenna door by pulling down the top of the spudger
    Vraag FixBot
    Voeg opmerking toe
  9. Nokia 8260 LCD Replacement: stap 9, afbeelding 1 van 1
    • Remove the antenna door.
    Vraag FixBot
    Voeg opmerking toe
  10. Nokia 8260 LCD Replacement: stap 10, afbeelding 1 van 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
    Vraag FixBot
    Voeg opmerking toe
  11. Nokia 8260 LCD Replacement, Circuit Board: stap 11, afbeelding 1 van 1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
    Vraag FixBot
    Voeg opmerking toe
  12. Nokia 8260 LCD Replacement: stap 12, afbeelding 1 van 1
    • Remove the back covering.
    Vraag FixBot
    Voeg opmerking toe
  13. Nokia 8260 LCD Replacement: stap 13, afbeelding 1 van 1
    • Remove the two screws at the top.
    Vraag FixBot
    Voeg opmerking toe
  14. Nokia 8260 LCD Replacement: stap 14, afbeelding 1 van 1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  15. Nokia 8260 LCD Replacement, LCD: stap 15, afbeelding 1 van 1
    • Detach the LCD from the logic board at the four metal hinges.
    • There are three pieces to the LCD: the front metal border, the LCD unit, and the plastic backing. Unless you are replacing the LCD, do not separate these three pieces.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Aaron Jen
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 27-94, Amido Spring 2010 Lid van Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 3,228
