Ga door naar hoofdinhoud
Nokia 6560 Keyboard Replacement
Wat je nodig hebt
  1. Nokia 6560 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia 6560 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 6560 Keyboard Replacement: stap 2, afbeelding 1 van 2 Nokia 6560 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 6560 Keyboard Replacement, Keypad: stap 3, afbeelding 1 van 2 Nokia 6560 Keyboard Replacement, Keypad: stap 3, afbeelding 2 van 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 6560 Keyboard Replacement: stap 4, afbeelding 1 van 2 Nokia 6560 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia 6560 Keyboard Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Unscrew the six T6 torx screws which attach the frame to the cell phone case.
    • Be careful not to scratch your display with the screw driver.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia 6560 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Lift the frame off of your cell phone.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia 6560 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Lift the keyboard out of the plastic frame.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tim Bergmann
35 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-17, Maness Winter 2010 Lid van Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Leden
24 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 32
Altijd: 1,809
