Ga door naar hoofdinhoud
Nokia 6086 Logic Board Replacement
Wat je nodig hebt
  1. Nokia 6086 Logic Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 6086 Logic Board Replacement: stap 2, afbeelding 1 van 3 Nokia 6086 Logic Board Replacement: stap 2, afbeelding 2 van 3 Nokia 6086 Logic Board Replacement: stap 2, afbeelding 3 van 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 6086 Logic Board Replacement: stap 3, afbeelding 1 van 3 Nokia 6086 Logic Board Replacement: stap 3, afbeelding 2 van 3 Nokia 6086 Logic Board Replacement: stap 3, afbeelding 3 van 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 6086 Logic Board Replacement, Upper Back Cover: stap 4, afbeelding 1 van 1
    • Turn the phone so that the back of the phone is facing forward.
    • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia 6086 Logic Board Replacement: stap 5, afbeelding 1 van 2 Nokia 6086 Logic Board Replacement: stap 5, afbeelding 2 van 2
    • Place the iPod opening tool under the tabs near the top of the phone.
    • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
    • Repeat for the left and the right sides.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia 6086 Logic Board Replacement: stap 6, afbeelding 1 van 2 Nokia 6086 Logic Board Replacement: stap 6, afbeelding 2 van 2
    • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
    • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia 6086 Logic Board Replacement: stap 7, afbeelding 1 van 3 Nokia 6086 Logic Board Replacement: stap 7, afbeelding 2 van 3 Nokia 6086 Logic Board Replacement: stap 7, afbeelding 3 van 3
    • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
    Vraag FixBot
    Voeg opmerking toe
  8. Nokia 6086 Logic Board Replacement, Base of The Phone: stap 8, afbeelding 1 van 2 Nokia 6086 Logic Board Replacement, Base of The Phone: stap 8, afbeelding 2 van 2
    • Locate the four screws.
    • Remove the screws using a T6 Torx screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  9. Nokia 6086 Logic Board Replacement: stap 9, afbeelding 1 van 2 Nokia 6086 Logic Board Replacement: stap 9, afbeelding 2 van 2
    • Turn the phone over.
    • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
    Vraag FixBot
    Voeg opmerking toe
  10. Nokia 6086 Logic Board Replacement: stap 10, afbeelding 1 van 2 Nokia 6086 Logic Board Replacement: stap 10, afbeelding 2 van 2
    • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
    Vraag FixBot
    Voeg opmerking toe
  11. Nokia 6086 Logic Board Replacement, Logic Board: stap 11, afbeelding 1 van 2 Nokia 6086 Logic Board Replacement, Logic Board: stap 11, afbeelding 2 van 2
    • Remove the logic board from the back cover of the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrea
70 Reputatie
5 handleidingen geschreven
Cal Poly, Team 26-30, Regan Spring 2010 Lid van Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 41
Altijd: 2,045
