Ga door naar hoofdinhoud
Nokia 6085h Front LCD Display
Wat je nodig hebt
  1. Nokia 6085h Front LCD Display, Battery: stap 1, afbeelding 1 van 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Front LCD Display: stap 2, afbeelding 1 van 1
    • Remove the phone's battery.
  3. Nokia 6085h Front LCD Display, Front LCD Display: stap 3, afbeelding 1 van 3 Nokia 6085h Front LCD Display, Front LCD Display: stap 3, afbeelding 2 van 3 Nokia 6085h Front LCD Display, Front LCD Display: stap 3, afbeelding 3 van 3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
  4. Nokia 6085h Front LCD Display: stap 4, afbeelding 1 van 2 Nokia 6085h Front LCD Display: stap 4, afbeelding 2 van 2
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
  5. Nokia 6085h Front LCD Display: stap 5, afbeelding 1 van 3 Nokia 6085h Front LCD Display: stap 5, afbeelding 2 van 3 Nokia 6085h Front LCD Display: stap 5, afbeelding 3 van 3
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Nokia 6085h Front LCD Display: stap 6, afbeelding 1 van 1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Nokia 6085h Front LCD Display: stap 7, afbeelding 1 van 3 Nokia 6085h Front LCD Display: stap 7, afbeelding 2 van 3 Nokia 6085h Front LCD Display: stap 7, afbeelding 3 van 3
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
Conclusie
Brett Balcer
240 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-46, Amido Fall 2010 Lid van Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,101
