Ga door naar hoofdinhoud
Nokia 6010 screen and speaker replacement
Wat je nodig hebt
  1. Nokia 6010 screen and speaker replacement, Battery: stap 1, afbeelding 1 van 3 Nokia 6010 screen and speaker replacement, Battery: stap 1, afbeelding 2 van 3 Nokia 6010 screen and speaker replacement, Battery: stap 1, afbeelding 3 van 3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 6010 screen and speaker replacement: stap 2, afbeelding 1 van 2 Nokia 6010 screen and speaker replacement: stap 2, afbeelding 2 van 2
    • Lift the battery near the bottom and pry up.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 6010 screen and speaker replacement, SIM Card: stap 3, afbeelding 1 van 1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 6010 screen and speaker replacement, Keypad: stap 4, afbeelding 1 van 2 Nokia 6010 screen and speaker replacement, Keypad: stap 4, afbeelding 2 van 2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
    Vraag FixBot
    Voeg opmerking toe
  5. Nokia 6010 screen and speaker replacement: stap 5, afbeelding 1 van 1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
    Vraag FixBot
    Voeg opmerking toe
  6. Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: stap 6, afbeelding 1 van 2 Nokia 6010 screen and speaker replacement, LCD Screen and Speaker: stap 6, afbeelding 2 van 2
    • Remove the six screws around the front of the phone body with a T6 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  7. Nokia 6010 screen and speaker replacement: stap 7, afbeelding 1 van 3 Nokia 6010 screen and speaker replacement: stap 7, afbeelding 2 van 3 Nokia 6010 screen and speaker replacement: stap 7, afbeelding 3 van 3
    • Insert your finger underneath the speaker piece and pry away from the phone body.
    • The plastic layer containing the LCD screen and speaker takes some force to remove.
    • There are 4 plastic tabs which keep it in place, but they are hard to press. Be careful and go tab by tab or use a spudger if you are nervous about using too much force.
    • The LCD and the speaker are attached to the same piece and must be replaced together.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Nicholas Hanne
129 Reputatie
8 handleidingen geschreven
Cal Poly, Team 14-45, Regan Winter 2010 Lid van Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Leden
32 handleidingen geschreven
1Gids Commentaar
Greatly appreciated !!!
Tobi Hunt - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 47
Altijd: 4,748
