Ga door naar hoofdinhoud
Nokia 3310 3G Screen Replacement
Wat je nodig hebt
    1. Nokia 3310 3G Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia 3310 3G Screen Replacement, Battery: stap 1, afbeelding 2 van 2
      • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Nokia 3310 3G Screen Replacement: stap 2, afbeelding 1 van 2 Nokia 3310 3G Screen Replacement: stap 2, afbeelding 2 van 2
      • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
      • This specific device did not come with a battery.
      Vraag FixBot
      Voeg opmerking toe
    1. Nokia 3310 3G Screen Replacement, Frame: stap 3, afbeelding 1 van 3 Nokia 3310 3G Screen Replacement, Frame: stap 3, afbeelding 2 van 3 Nokia 3310 3G Screen Replacement, Frame: stap 3, afbeelding 3 van 3
      • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
      • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Nokia 3310 3G Screen Replacement, Motherboard: stap 4, afbeelding 1 van 3 Nokia 3310 3G Screen Replacement, Motherboard: stap 4, afbeelding 2 van 3 Nokia 3310 3G Screen Replacement, Motherboard: stap 4, afbeelding 3 van 3
      • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
      Vraag FixBot
      Voeg opmerking toe
    1. Nokia 3310 3G Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Nokia 3310 3G Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Nokia 3310 3G Screen Replacement, Screen: stap 5, afbeelding 3 van 3
      • With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
      • Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Aaron LeBlanc
753 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 Leden
32 handleidingen geschreven
4Gids Commentaar
If you can break the screen without taking it apart, then you must not be human
Feyrowan - Antwoord Deel
The Cylons are greeting you.
M. H. - Antwoord Deel
Thank you!
I dont have cash for a new one,
but i could fix my old one.
There was soup on the display inside,
cleaned it, screen is clear now.
Yeay!
fred - Antwoord Deel
Where could I get a replacement screen?
Secret - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 54
Altijd: 2,702
