Ga door naar hoofdinhoud
Nokia 2115i keypad replacement
Wat je nodig hebt
  1. Nokia 2115i keypad replacement, Nokia 2115i Battery: stap 1, afbeelding 1 van 3 Nokia 2115i keypad replacement, Nokia 2115i Battery: stap 1, afbeelding 2 van 3 Nokia 2115i keypad replacement, Nokia 2115i Battery: stap 1, afbeelding 3 van 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
    Vraag FixBot
    Voeg opmerking toe
  2. Nokia 2115i keypad replacement: stap 2, afbeelding 1 van 2 Nokia 2115i keypad replacement: stap 2, afbeelding 2 van 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
    Vraag FixBot
    Voeg opmerking toe
  3. Nokia 2115i keypad replacement, Faceplate: stap 3, afbeelding 1 van 3 Nokia 2115i keypad replacement, Faceplate: stap 3, afbeelding 2 van 3 Nokia 2115i keypad replacement, Faceplate: stap 3, afbeelding 3 van 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
    Vraag FixBot
    Voeg opmerking toe
  4. Nokia 2115i keypad replacement, Removing the Keypad: stap 4, afbeelding 1 van 2 Nokia 2115i keypad replacement, Removing the Keypad: stap 4, afbeelding 2 van 2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Shane
80 Reputatie
6 handleidingen geschreven
Cal Poly, Team 14-38, Forte Fall 2010 Lid van Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 1,413
