Inleiding
If you are having trouble with the USB port or solar panel, then these steps should be used to replace it altogether.
Wat je nodig hebt
Turn over the device so that the back of the device is facing up.
Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
Één andere persoon heeft deze handleiding voltooid.
