Ga door naar hoofdinhoud
Nintendo Wii U Pro Controller ABXY Buttons Replacement
Wat je nodig hebt
  1. Nintendo Wii U Pro Controller ABXY Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 2, afbeelding 1 van 2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller ABXY Buttons Replacement, Joystick: stap 3, afbeelding 1 van 1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 4, afbeelding 1 van 2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 4, afbeelding 2 van 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 5, afbeelding 1 van 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 6, afbeelding 1 van 1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 7, afbeelding 1 van 1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 8, afbeelding 1 van 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller ABXY Buttons Replacement, ABXY Buttons: stap 9, afbeelding 1 van 3 Nintendo Wii U Pro Controller ABXY Buttons Replacement, ABXY Buttons: stap 9, afbeelding 2 van 3 Nintendo Wii U Pro Controller ABXY Buttons Replacement, ABXY Buttons: stap 9, afbeelding 3 van 3
    • Now that the joysticks are removed, locate the screws on the left and right side of the controller (highlighted in the photos) and use the J0 bit to remove these 4 mm screws. This will allow you to pull out the controller board
  10. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 10, afbeelding 1 van 2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 10, afbeelding 2 van 2
    • Once these two screws have been removed, you may go ahead and remove the board from the controller housing. Now, direct your attention to the front panel of the controller. Remove the buttons and wipe them down completely with rubbing alcohol and a q-tip. Set them aside to dry for several minutes.
  11. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 11, afbeelding 1 van 2 Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 11, afbeelding 2 van 2
    • Remove the rubber covers (circled in the photo) from the ABXY sensors from the control board that was removed from the housing.
  12. Nintendo Wii U Pro Controller ABXY Buttons Replacement: stap 12, afbeelding 1 van 1
    • Wipe down the rubber cover pad completely with rubbing alcohol and a q-tip. Use compressed air to clean off the contact sensors (highlighted by the red circle).
Conclusie
To reassemble your device, carefully follow these instructions in reverse order.
4 andere personen hebben deze handleiding voltooid.
Will Grabb
204 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Harley Fall 2015 Lid van IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Leden
15 handleidingen geschreven
Één opmerking
Thanks so much! I spilt milk on my controller and got the buttons all gummed up but this guide helped me clean them up, including dust and the gunk inside of it, you saved me a ton of money!
Patrick Caudill - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 61
Altijd: 4,452
