Ga door naar hoofdinhoud
Nintendo Wii U Pro Controller Joystick Replacement
Wat je nodig hebt
  1. Nintendo Wii U Pro Controller Joystick Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller Joystick Replacement: stap 2, afbeelding 1 van 2 Nintendo Wii U Pro Controller Joystick Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller Joystick Replacement, Joystick: stap 3, afbeelding 1 van 1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller Joystick Replacement: stap 4, afbeelding 1 van 2 Nintendo Wii U Pro Controller Joystick Replacement: stap 4, afbeelding 2 van 2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller Joystick Replacement: stap 5, afbeelding 1 van 1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller Joystick Replacement: stap 6, afbeelding 1 van 1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller Joystick Replacement: stap 7, afbeelding 1 van 1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller Joystick Replacement: stap 8, afbeelding 1 van 1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
Eindstreep
9 andere personen hebben deze handleiding voltooid.
Jesse Burton
586 Reputatie
3 handleidingen geschreven
IUPUI, Team 2-2, Harley Fall 2015 Lid van IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
4 Leden
13 handleidingen geschreven
Één opmerking
Where can I buy those Nintendo wii u pro controller analog joystick prints? I can only find them for the wii u Gamepad on ebay.
Thx for a good guide!
Simon Denmark
Simon Martin Sørensen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 122
Altijd: 9,273
