Ga door naar hoofdinhoud
Nintendo Wii Remote Speaker Replacement
Wat je nodig hebt
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: stap 1, afbeelding 1 van 2 Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: stap 1, afbeelding 2 van 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo Wii Remote Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo Wii Remote Speaker Replacement: stap 3, afbeelding 1 van 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo Wii Remote Speaker Replacement: stap 4, afbeelding 1 van 2 Nintendo Wii Remote Speaker Replacement: stap 4, afbeelding 2 van 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo Wii Remote Speaker Replacement, Speaker: stap 5, afbeelding 1 van 3 Nintendo Wii Remote Speaker Replacement, Speaker: stap 5, afbeelding 2 van 3 Nintendo Wii Remote Speaker Replacement, Speaker: stap 5, afbeelding 3 van 3
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Emily
2.015 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-44, Amido Spring 2013 Lid van Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Leden
29 handleidingen geschreven
2Gids Commentaar
Thank you, u help me to fix it.
joon lew - Antwoord Deel
That's cool and all, but what speaker am I supposed to buy?
Shadow - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 169
Altijd: 9,577
