Ga door naar hoofdinhoud
Nintendo Wii Remote Motherboard Replacement
Wat je nodig hebt
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: stap 1, afbeelding 1 van 2 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: stap 1, afbeelding 2 van 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    Vraag FixBot
    Voeg opmerking toe
  2. Nintendo Wii Remote Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. Nintendo Wii Remote Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Nintendo Wii Remote Motherboard Replacement: stap 4, afbeelding 1 van 2 Nintendo Wii Remote Motherboard Replacement: stap 4, afbeelding 2 van 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Vraag FixBot
    Voeg opmerking toe
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Nintendo Wii Remote Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    Vraag FixBot
    Voeg opmerking toe
  6. Nintendo Wii Remote Motherboard Replacement: stap 6, afbeelding 1 van 2 Nintendo Wii Remote Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Grasp the edges of the motherboard and pull it straight away from the case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
36 andere personen hebben deze handleiding voltooid.
Emily
2.015 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-44, Amido Spring 2013 Lid van Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Leden
29 handleidingen geschreven
7Gids Commentaar
Where do you find a motherboard and how much do they typically cost?
Jeff - Antwoord Deel
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Antwoord Deel
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign - Antwoord Deel
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Antwoord Deel
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 381
Altijd: 40,510
