Ga door naar hoofdinhoud
Nintendo Switch Pro Controller Trigger Button Replacement
Wat je nodig hebt
  1. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: stap 1, afbeelding 1 van 1
    • Flip the controller over so the model stickers face the ceiling.
    • Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
    Vraag FixBot
  2. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: stap 2, afbeelding 1 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: stap 2, afbeelding 2 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the handle covers: stap 2, afbeelding 3 van 3
    • Carefully remove the handle covers by pulling them away from the main body.
    Vraag FixBot
  3. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: stap 3, afbeelding 1 van 1
    • Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
    Vraag FixBot
  4. Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: stap 4, afbeelding 1 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: stap 4, afbeelding 2 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Unclip the plastic cover: stap 4, afbeelding 3 van 3
    • Carefully pry away the clear plastic cover using your fingernail.
    Vraag FixBot
  5. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the clear plastic cover: stap 5, afbeelding 1 van 1
    • Remove the clear plastic cover.
    Vraag FixBot
  6. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: stap 6, afbeelding 1 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: stap 6, afbeelding 2 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the battery: stap 6, afbeelding 3 van 3
    • Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
    • Only a small amount of force is needed.
    Vraag FixBot
  7. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: stap 7, afbeelding 1 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: stap 7, afbeelding 2 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: stap 7, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
    • The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
    • The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a narrow PH1 Phillips screwdriver with a longer shaft to reach these screws.
    Vraag FixBot
  8. Nintendo Switch Pro Controller Trigger Button  Replacement: stap 8, afbeelding 1 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement: stap 8, afbeelding 2 van 3 Nintendo Switch Pro Controller Trigger Button  Replacement: stap 8, afbeelding 3 van 3
    • There's an adhesive pad located in the center of each handle. It will require a bit of force to pry away the front cover, but be mindful of the attached ribbon cable.
    • Delicately take off the plastic cover from the controller.
    • Don't completely remove the front cover just yet, as it's still attached to the motherboard via a white ribbon cable.
    Vraag FixBot
  9. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the flap: stap 9, afbeelding 1 van 2 Nintendo Switch Pro Controller Trigger Button  Replacement, Open the flap: stap 9, afbeelding 2 van 2
    • Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
    Vraag FixBot
  10. Nintendo Switch Pro Controller Trigger Button  Replacement, Disconnect the interconnect cable: stap 10, afbeelding 1 van 2 Nintendo Switch Pro Controller Trigger Button  Replacement, Disconnect the interconnect cable: stap 10, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
    Vraag FixBot
  11. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the front case: stap 11, afbeelding 1 van 1
    • Remove the front case.
    Vraag FixBot
  12. Nintendo Switch Pro Controller Trigger Button  Replacement, Remove the screws: stap 12, afbeelding 1 van 1
    • Remove the two 6.8 mm-long screws on the top circuit board using a Phillips screwdriver.
    Vraag FixBot
  13. Nintendo Switch Pro Controller Trigger Button  Replacement, Open the ZIF connector: stap 13, afbeelding 1 van 2 Nintendo Switch Pro Controller Trigger Button  Replacement, Open the ZIF connector: stap 13, afbeelding 2 van 2
    • Use a spudger to flip up the locking tab on the ZIF connector.
    Vraag FixBot
  14. Nintendo Switch Pro Controller Trigger Button  Replacement: stap 14, afbeelding 1 van 2 Nintendo Switch Pro Controller Trigger Button  Replacement: stap 14, afbeelding 2 van 2
    • Remove the black ribbon cable from its connector.
    • Only a small amount of force should be needed to remove the ribbon cable.
    Vraag FixBot
  15. Nintendo Switch Pro Controller Trigger Button  Replacement: stap 15, afbeelding 1 van 2 Nintendo Switch Pro Controller Trigger Button  Replacement: stap 15, afbeelding 2 van 2
    • Remove the trigger buttons from the plastic cover.
    Vraag FixBot
Conclusie
16 andere personen hebben deze handleiding voltooid.
Simon Lin
434 Reputatie
1 Handleiding geschreven
Cal Poly, Team S11-G2, Regan Fall 2019 Lid van Cal Poly, Team S11-G2, Regan Fall 2019
CPSU-REGAN-F19S11G2
5 Leden
45 handleidingen geschreven
6Gids Commentaar
This guide does show how to remove the trigger/bumper casing and board from the controller but does not show how to remove the triggers/bumpers from the casing they are in.
Boushi Adams - Antwoord Deel
Yeah, this is a pretty big point to be missing, especially with the Flex Cable for the shoulder button inputs being right beside the post you need to pull out to remove the ZL and ZR buttons. Guidance on how to remove the post safely without damaging the cable would be great.
Alex Crocker - Antwoord Deel
Used the guide to repair a shattered right shoulder button successfully. Thanks!
Christian - Antwoord Deel
After reinstalling the shoulder buttons I have found them to stop working, all four, I checked my ribbon cable from the buttons to the board and even replaced it. I also confirmed the ribbon cable connector on the main board is working as well. Can anyone make any further troubleshooting suggestions?
David - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 84
Afgelopen 30 dagen: 538
Altijd: 57,769
