Ga door naar hoofdinhoud
Nintendo Switch OLED Model Dock Baseplate Replacement
Wat je nodig hebt
  1. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: stap 1, afbeelding 1 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: stap 1, afbeelding 2 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the rear cover: stap 1, afbeelding 3 van 3
    • Use your fingers to pull the rear cover away from the frame and release its plastic clips.
    • Remove the rear cover.
  2. Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the baseplate: stap 2, afbeelding 1 van 2 Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the baseplate: stap 2, afbeelding 2 van 2
    • Use a Y0 screwdriver to unfasten the 7.5 mm-long screw securing the baseplate to the frame.
  3. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: stap 3, afbeelding 1 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: stap 3, afbeelding 2 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the screw cover: stap 3, afbeelding 3 van 3
    • Insert an opening tool between the frame and the plastic screw cover at the bottom-left corner.
    • Pry up with the opening tool to separate the screw cover from the frame.
    • Remove the screw cover.
  4. Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the midframe: stap 4, afbeelding 1 van 2 Nintendo Switch OLED Model Dock Baseplate Replacement, Unfasten the midframe: stap 4, afbeelding 2 van 2
    • Use a Y0 screwdriver to remove the seven screws securing the midframe to the frame:
    • Four 3.9 mm screws
    • Three 7.5 mm screws
    • One 3.9 mm screw
  5. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: stap 5, afbeelding 1 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: stap 5, afbeelding 2 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the midframe: stap 5, afbeelding 3 van 3
    • Use your fingers to remove the midframe from the frame.
  6. Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: stap 6, afbeelding 1 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: stap 6, afbeelding 2 van 3 Nintendo Switch OLED Model Dock Baseplate Replacement, Remove the baseplate: stap 6, afbeelding 3 van 3
    • Use your fingers to pull the baseplate away from the frame and release it from its plastic clips.
    • Remove the baseplate.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch OLED Answers community for help.
Alex Diaz-Kokaisl
161.945 Reputatie
769 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.410 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 60
Altijd: 1,971
