Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Gently lift the back panel up, separating it from the front panel.
Grab the Z-button by the peg with tweezers and lift it out of the controller.
Carefully unhook the cable that is looped around the peg.
Press the tip of the soldering iron against one of the leads and wait until solder is viscous. Carefully pull wire away from lead.
Repeat for the second lead and wire.
Using tweezers, unhook the wires from the small black bracket keeping them attached to the circuit board.
3 andere personen hebben deze handleiding voltooid.
