Ga door naar hoofdinhoud
Nintendo GameCube Controller Joystick Replacement
Wat je nodig hebt
  1. Nintendo GameCube Controller Joystick Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Joystick Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Joystick Replacement, Z Button: stap 3, afbeelding 1 van 2 Nintendo GameCube Controller Joystick Replacement, Z Button: stap 3, afbeelding 2 van 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Joystick Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Joystick Replacement: stap 5, afbeelding 1 van 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Joystick Replacement, Joystick: stap 6, afbeelding 1 van 2 Nintendo GameCube Controller Joystick Replacement, Joystick: stap 6, afbeelding 2 van 2
    • Grab the base of the grey cover and pull it off.
    • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
Conclusie
31 andere personen hebben deze handleiding voltooid.
Sean Michel
2.600 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-44, Regan Winter 2013 Lid van Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Leden
32 handleidingen geschreven
13Gids Commentaar
Great guide, but I'm looking to buy replacement joysticks and I can't find them anywhere. Where would I find those?
Joe Freedman - Antwoord
When I removed the joystick it would come off. The plastic was stuck too hard to the joystick so I accidentally broke it in half. Is there anyway to glue it back together?
Mattias Wirsenius - Antwoord
@Tyler Lovejoy - That's already part of the controller.
@Joe Freedman - Try Amazon.com
@Mattias Wirsenius - At this point it would be best to buy a new controller.
builderman1q2w3e4r - Antwoord
This guide is quite unhelpful; it tells you how to remove the stick but not how to repair it. My controller's joystick has sunken into the controller and stays slightly tilted if i move it to the right. Yet when I go to the "rogue joystick" portion of the troubleshooting guide, it tells me to repair the joystick if it's not correctly attached to the motherboard. Seriously, there needs to be a more in-depth guide if such repairs are possible.
J DC - Antwoord
without taking the controller completely apart, pull the joystick straight up with your hand
McRedstoneYT -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 102
Afgelopen 30 dagen: 463
Altijd: 106,145
