Ga door naar hoofdinhoud
Nintendo GameCube Controller C Stick Replacement
Wat je nodig hebt
  1. Nintendo GameCube Controller C Stick Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller C Stick Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller C Stick Replacement, Z Button: stap 3, afbeelding 1 van 2 Nintendo GameCube Controller C Stick Replacement, Z Button: stap 3, afbeelding 2 van 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller C Stick Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller C Stick Replacement: stap 5, afbeelding 1 van 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller C Stick Replacement, C Stick: stap 6, afbeelding 1 van 3 Nintendo GameCube Controller C Stick Replacement, C Stick: stap 6, afbeelding 2 van 3 Nintendo GameCube Controller C Stick Replacement, C Stick: stap 6, afbeelding 3 van 3
    • Use your fingers to grab the two sides of the connector and gently wiggle out.
    • Be sure not to pull on the cables. This may pull the cables out and damage your device even more.
  7. Nintendo GameCube Controller C Stick Replacement: stap 7, afbeelding 1 van 2 Nintendo GameCube Controller C Stick Replacement: stap 7, afbeelding 2 van 2
    • Grab the yellow cover by the base and pull it off.
    • During reassembly, make sure the slots inside the joy stick line up so they can fit back together.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Sean Michel
2.496 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-44, Regan Winter 2013 Lid van Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Leden
26 handleidingen geschreven
2 opmerkingen
This doesnt help by c stick is broken and i need help. Up and down work just fine on it, but it doesnt rgister left and right. Anybody have any help?
Shane Roy - Antwoord
I did a mod on it and it worked fine until then but its really weird that left and right arent working but up and down are i couldve accidentally got hot glue in there... Any way to buy an entirely new c stick unit?
Shane Roy -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 72
Altijd: 21,106
